Latest post 10-08-2008 6:57 AM by kawo. 25 replies.
Page 2 of 2 (26 items) < Previous 1 2
  • 10-08-2008 6:57 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    Re: Beoliving Curtains
    Like Stefan, I also have setup which is not based on B&O's suggested products. The Stewart Screens are without any doubt the best on the market, but very very expensive. I have a motorized mult masking screen (Davision) and  a JVC HD1 projector. Both are controlled by the Lintronic box, the screen via IR and the projector via RS232. Works without any problem.
    In the future I will integrate light control with the JB Media Interface which is now available as a pro version to set light levels by percentage with an RF light control system like the F20.
    http://cms.jbmedia.de/index.php?option=com_content&task=view&id=84&Itemid=1&lang=en
    This is the budget way to go, may be not that relaible as the EIB/KNX or full Crestron integration but for a fraction of the cost.
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
