Latest post 06-28-2007 7:28 AM by Alex. 11 replies.
Page 1 of 1 (12 items)
  • 05-14-2007 11:20 AM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Laptop about to die....advice please!
    woke this morning to find the laptop which I use mainly for emails and surfing in the living room had crashed. So on rebooting I find it is very slow and the hard drive is clicking and crashing about. You remeber what the original drives used to sound like? Bit like that but louder.
    Ok I've transfered the critical files to the network drive but idealy I'd like  to be able to just transfer the whole lot and then put it onto the new hard disk when it arrives. tried using XP's file transfers utility but it just crashes.
    Any thoughts?
    cheers,
    Kevin
  • 05-14-2007 12:08 PM In reply to
    Re: Laptop about to die....advice please!
    Kevin,
    What you need to do is an Image backup which means everything on your new hard drive is 100% the same as the old.
    I suggest you use a product that I use called Drive Image from R-Tools, it works very well and you can even open the backup image up on another machine as a virtual drive.
    You can download it from HERE
    Keith..
    Regards Keith....
  • 05-14-2007 12:10 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Kevin,
     you might want to look at
    http://www.miray.de/products/sat.hdclone.html
    to help you.
    Regards
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 05-15-2007 5:10 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Keith Saunders:
    Kevin,
    Keith..
    I used this recently to clone an existing drive to a new larger one (and then Partition Magic to resize partitions etc) to save having to reinstall when upgrading my system hard drive. I was impressed that it worked so well as it was free to use (for up to 15 days).
  • 05-15-2007 10:37 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Well the news is not good[:'(] tried both products. The first requires a 2nd writeable drive usb etc requires the upgrade so no go there and the 2nd which I shall use when everything is up and running didn't get a chance 'cause the blue screen appeared and the final reboot led to the inevitable "no operating system" message.
    Thanks for all the advice and help though.
    Just have to wait for the new drive  and get on with loading everything on again ... yawn!
    cheers,
    Kevin
  • 05-21-2007 2:31 PM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Hi Kevin
    Look at your PMs
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 05-21-2007 2:47 PM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Thansk for your help Yann I've sent you a PM back.
    Justa quick update.
    The drive died altogether before I was able to do anymore. I'm still rebuilding with all those usefull bits of software that have to be uploaded but at least I'm surfing again.
    cheers,
    kevin
  • 05-28-2007 10:28 AM In reply to
    In hindsight everyone is an expert. Have you thought about two drives, connected with a RAID something so that they automatically duplicate themselves.
    With memory coming down in price this is a good way to protect your stuff without actually having to do anything (after it's set up).
    Cheers
    Brian
  • 06-24-2007 5:45 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    RAID isn't really an option on a laptop is it! Laughing
     Weekly top artists:
  • 06-27-2007 6:48 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    No raid won't work but Brian I am connected to a network which has dedicated network drive so I intend to do something similar as you suggest and use the image software to do a back up image.
    Unfortunately the drive was not the only problem, it looks like the hard disk controller on the motherboard is down and the thing just won't play any more. Just waiting for a replacement at the moment and can then hopefully just swap drives.
  • 06-28-2007 3:18 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    just an update.
    The new laptop arrived yesterday I got a refurbished IBM T40 cosmeticaly in perfect nick with all the IBM goodies on it including Ghost for 400€.  Still have to get used to the German keyboard thogh so excuse any typing errors lol
  • 06-28-2007 7:28 AM In reply to
    • Alex
    • Posts 2,990
    Laughing Laughing Great laptop though! Stick Linux on it and it'll be bombproof...
     Weekly top artists:
