Hi there all, I know this is a subject that has been around for long, but even doing some research and a lot of time wasted in it, I can't get it to work as I wanted...I'm sure it's really easy to solve, but here I go:I have a 6 month old Beovision 7 40" and a Mac Mini C2D fully equiped. I wired the video through a DVI to HDMI cable, and the sound via regular way. The thing is that I can't get the proper resolution in order to get the Full High Definition to watch a divX movie. When I start the mac mini resolution is set default to 1900x1600 and I don't understand why if I set it to the highest one (1920 x 1080 ) I think the screen gets black and doesn't support it.
Which resolution should I set in order to watch the movies the best way? I don't wanna loose some screen by overscaning the resolution...
Thank you very much to everyone ;)
