Latest post 09-29-2008 2:12 AM by Dillen. 2 replies.
Page 1 of 1 (3 items)
  • 09-28-2008 9:55 PM
    • Barton
    • Not Ranked
    • Joined on 09-13-2008
    • Posts 2
    • Silver Member
    Hmm [^o)] Beogram 1700
    I just bought a Beogram 1700 TT. It operates a little slower than 33 1/3. Would a new belt do the trick? It could be the original belt on this unit.
    Thanks!
    Filed under:
  • 09-29-2008 1:48 AM In reply to
    Re: Beogram 1700
    Worth a try though it may be electrical.
  • 09-29-2008 2:12 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1700
    Welcome to Beoworld !  And thanks for signing up as a silver member, your support is greatly appreciated !
    There are speed fine adjustments reachable from below through two small holes in the bottom plate. The trimmers inside could be bad, that's very common, but could also just need a little motion.
    Normally, the speeds and the tracking force are the only things you need to adjust.
