nrhalne:Hi
I am looking for a Beovision 3-32, and I had search this forum what to look for, and I found this AR screen but wat is it. I also need
some information for the serialnumbers - build/year/opdate/software.
Thanks Nrhalne
As for the AR screen, I suppose it will be OK if you buy a BV3 with one of these screens, but I got one off eBay to replace my 'normal' screen and frankly, I didn't notice much difference although I had read comments from others who said it made a huge difference. I couldn't see it though.
Also, I find the AR screen far trickier to clean. It takes more far more time to ensure all surface streaks are removed.
