I dunno if anybody remembers this thread:
http://forum.beoworld.org/forums/thread/106583.aspx
I never did get the old CD mech to work... However, I managed to get a complete BC8000 CD assembly from some service center clearup. I checked the preliminary laser current adjustment (1 kohms over R3105 + R3106), plugged the mech in, and it spun the CD and started to play right away!
However, since the actual BC8000 service manual is not on site and I can note a number of discrepancies between the BC9500 manual and this machine, I plugged it off instead of tweaking anything further. can anyone confirm if this is the correct way of adjusting this:
- Laser current: DC voltmeter across R3102, adjust R3106 to 50 mV +/- 5 mV;
- Focus offset: test mode check no.2, adjust R3146 until display shows 02; further adjust until there is 400 mV +/- 40 mV accross R2136
(and oh yes, the new CD mech is similar with regards the spindle motor: just two leads directly soldered on the PCB)
