Latest post 09-29-2008 4:34 PM by Max. 6 replies.
Page 1 of 1 (7 items)
  • 09-27-2008 3:08 AM
    Reliable back up drive
    My Iomega 1Tb external disc has just failed - as it is the back up disc, nothing lost! I need a new one with Firewire - any suggestions to what would be a good one?
  • 09-27-2008 3:41 AM In reply to
    Re: Reliable back up drive
    I have a Seagate that is no longer produced. But they have a new product line called Free Agent which also comes with Firewire 400 for PC and FireWire 400/800 for Mac. If you have a PC I suggest you use eSATA if possible. I have it and it's really fast.
  • 09-27-2008 3:45 AM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    I have a LaCie D2 Quadra. If you have a Mac then this drive has Firewire 800/400 & USB. Its daisy chain-able and comes already formatted for Macs and Time Machine. Best price I found at the time was from the Apple Store.
    How about a Time Capsule?
  • 09-27-2008 11:05 AM In reply to
    I agree LaCie D2 Quadra is a good choice and is very reliable.  For backup though, Time Capsule is really wonderful.  I have the 1 TB version and although I have not needed to do a full restore, I have restored files that I had inadvertently deleted several months ago.  You can store other data on the Time Capsule not only backup data.
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 09-27-2008 12:21 PM In reply to
    • Sal
    • Top 200 Contributor
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    I hope I'm not the only person on Beoworld who adores his Drobo. (www.drobo.com) No-thinking Redundunt storage, and expandable to 16TB.
    -Sal
    Love B&O, but no longer addicted.
  • 09-29-2008 6:23 AM In reply to
    Hello,
    I have the Western Digital My Book 320Go in silver color. this one matches perfectly with my iMac 24" Alu.
    Good product but you can find better.
    Guy
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 09-29-2008 4:34 PM In reply to
    • Max
    • Not Ranked
    • Joined on 04-19-2007
    • Devon
    • Posts 64
    Hi Peter,
    I have a Mybook 1TB Studio - no problems and really quick over FW if you need the throughput. Some reasonable reviews on Amazon (inc. yours truly):
    http://www.amazon.co.uk/Western-Digital-Studio-Firewire-External/dp/B000W9Q2EW/ref=sr_1_1?ie=UTF8&s=electronics&qid=1222720119&sr=8-1
    Max.
    My B&O is in my Bio.
