Thank you,
I was afraid that the integration would not be that good as a twin-tuner harddrive box is such a different beast compared to a ordinary box, which functions-wise maps almost 1-to-1 to the well established primitives of the built-in analog tuner.
The use-cases I can think of in decreasing order of importance are:
1. Most important is that watching tv in real-time works as expected.
2. Pausing and catching up within a show.
3. Navigating EPG:s
4. Watching recorded shows.
5. Timer controlled recordings.
6. Setting up more complex recording scenarios.
7. Box configuration
The first two should work using beo4 buttons without accessing menus.
My current box only support use case 1 & 7, so obviously integrating modern boxes is much more complex.
/Peter
