Latest post 11-30-2011 4:14 PM by Guy1680. 10 replies.
Page 1 of 1 (11 items)
  • 09-26-2008 3:06 AM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Beolink 5000 Question
    Dear all,
    I have just replaced my broken Beolink 5000 with an almost new one. However, I noticed that on the back side buttons, instead of the clock button it does have one button named "control". Does anyone know what this is used for?
    Regards
     Spiros
    Best regards
    Spiros
  • 09-26-2008 3:55 AM In reply to
    Re: Beolink 5000 Question
    Spiros,
    There was four versions of the Beolink 5000 which I am aware of. A Mark I & II for US and a Mark I & II for everyone else.
    I have never seen a US version, but you may wish to look at the four digit "Type" number
    Type 1534 was a US Mark I
    Type 1623 was a US Mark II
    Type 1531 was a Mark I for everyone else
    Type 1620 was a Mark II for everyone else
    Regards Keith....
  • 09-26-2008 4:02 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    The CONTROL button is used for controlling another device whilst another source is playing,
    f.e. whilst a cd is playing, press CONTROL + TAPE to be able to control the tape-deck.
    (without the Beomaster changing source)
  • 09-26-2008 4:05 AM In reply to
    Useful when you want to rewind a tape while listening to the radio for example.
    Some 2way hifi are not compatible. It won't work on a Beosound2500 for example.
    Shift+Status will display the Clock.
  • 09-26-2008 6:20 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Dear All,
     Thank you very much for the feed back. I think the control button is much more useful than the clock one!!!!!
     I'll try everything tonight.
    Best regards
    Spiros
  • 02-25-2011 5:10 AM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Shift+Status doesn't bring up the clock on my Beolink 5000 (the control button version).  Anyone have any ideas how to get the clock, or is the only way to access the Programming function?
    Regards
    Guy
  • 02-25-2011 5:22 AM In reply to
    • stefan
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    SHIFT - STATUS should display the clock. Do you have a two-way master, that sends the clock data?
    Stefan
  • 02-25-2011 6:27 AM In reply to
    • Guy1680
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Yes - I'm trying it with my BC9500 - and the remote is set to two way audio, plus the correct time is set.  Software version of my remote is 2.2.  Strange that it doesn't work!
  • 02-25-2011 6:45 AM In reply to
    • stefan
    • Posts 1,733
    Yes, strange. Are all two-way functions working? Volume level, Timer programming in Stdby mode....?
    And what does your BL display, if you press SHIFT - STATUS?
    Stefan
  • 02-25-2011 6:56 AM In reply to
    • Guy1680
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    All other two-way functions are working such as volume and time programming.  If I press SHIFT then STATUS it only seems to give/get the STATUS command, hence the screen simply displays the radio station or whatever.  Yet the SHIFT button is working fine: SHIFT then RADIO gives A.Aux, for instance.
    May have to leave it for now - a new bathroom floor needs laying....Wink
    Thanks for your help anyway!
  • 11-30-2011 4:14 PM In reply to
    • Guy1680
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Just worked this one out!  When I turn the BL5000 over, 'SHIFT' then 'CONTROL' displays the current time.  I suppose I should have guessed this, as CONTROL was the 'new' button.
