1st March February 2012
Latest post 09-27-2008 7:16 AM by Jackplug. 16 replies.
09-24-2008 5:16 PM
Jackplug
- Joined on 07-31-2007
- UK
- Posts 83
Well, I don't get on here too much but I popped in last night and a very kind person fixed my BS2300 issues. So I thought I'd try again with a slightly more complex one.... OK, so I spent all my money on B&O over the years and now the house is full of stuff, and I mean full. However, it seems that I still struggle with simple things, either age or stupidity, not sure which, has done this to me. I have an AVANT as video master. This is then wired to an ML distro box 'VIDEO' socket. From the box 'AUDIO' socket, I have an ML to my BS2300 (via Beolink Converter - 1611). From the 'LINK 1' socket I have another ML to an MX7000 (upstairs) also via another Beolink Converter 1611. What I'm lacking is the ability to control the AVANT (and thus turn on the modulator) via the MX7000. I can access the audio system fine from the MX7000 but thought I could still access the other video sources (SAT, VIDEO, DVD sound) via the config I have. I know there can only be 1 Audio master and 1 Video master, but how then does a Link TV work in all that. It's not a cabling issue, tested all that. So I'm guessing it's a 'OPTION' setup type thing? I've set the BS2300 up (which is in a different room to the AVANT). I just used a Beolink 1000 with the old "SOUND 2 STORE' I've set up the MX again with Beolink 1000 but pressed 'PICTURE 2 STORE' But there must be some clash with either the AVANT or cos I'm using a hybrid ML / AAL lash up... dunno? The only other guess is that I've not actually got a true ML arrangement. Is it that, the Link 1-4 sockets on the ML distribution box are really only for Beolink Passive ML / MCL type devices (in link rooms) and NOT another TV or such??? I ask this because I do have a Beolink Passive connected directly to the BS2300 powerlink, and just driving a pair of CX100s in the kitchen. I tried this with the ML distro box by connecting an ML cable to the Passive Amp and then attaching the IR sensor. That all worked and I was able to activate the AVANT and then the BS2300 via the Passive Amp as if it were in a link room, (just covering up the IR window on the AVANT while I did it). Is there any way I can access the AVANT sources via the MX in this config? I've tried using both a Beolink 1000 and Beo 4 on the MX by pressing 'LINK' then V.TAPE or SAT etc but I don't even get the sound from those sources, through the MX speakers. Obviously, if I just press TV, DVD etc then I just get the Local MX TV control. Before anyone asks, yes the MX is fed via a distributed RF from the AVANT modulator and I can view the AVANT sources but only once the modulator is activated by me going through the BS2300, which means going back downstairs to do that, which defeats the object a bit... Anyway, is there a comprehensive manual out there for config of ML networks. I've only got the old one that came with Beolink 1000 on 'How to set up the Beolink System' which was a bit before ML arrived. Any tips greatly appreciated.... Thanks
Jack
BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
BL5, BL8000, BL6000, BL Penta3, BL3500
Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Re: Beolink, on the blink?
Gosh, complex system! Have you downloaded the PCG? Can be found HERE. At first I thought it may be something to do with having two Beolink converters, them I thought it may be an option thing. I know you can change your Beo4 so that every command it sends is a link command, but don't think that's an issue here. Peter or Keith Saunders will likely be here shortly to help, they are a bit more knowledgable than me. Andy T.
Peter
- Joined on 02-12-2007
- Posts 9,572
The MX needs to be a slave so you need to set it to Option 6 (Picture, 6, Store) Should work fine with both audio and video commands. You have it set as a master at present.
Peter
- Posts 9,572
There is a Masterlink manual on site and I believe it is on the official site as well in which case it is free. If I am wrong, join as a silver member and there are lots of manuals! Andy is right - the Product Configuration guide is well worth trying out as well.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
I haven't had the time to read the whole post, but the MX7000 is a bit special in the sense that it can have 2 options, for example it can be set to option 1+5. The PCG will tell you which options. Once when I added a TV in my setup, my dealer changed the setting of my MX7000 TV and it never worked fine for years. It is only when I downloaded the PCG that I could set the right options again!
Peter
- Posts 9,572
That could well be true - my LX6000 is similar in that case. I cannot run the PCG on my Mac but maybe someone can on a PC.
Jackplug
- UK
- Posts 83
Hey, Thanks for all the replies, Peter I will try the MX options you suggest. I never remembered that there were more options to try other than 1 + 2. My old MX5500 used to respond to options 1,2,4 I think, which made it do funny things. Didn't know about option 5,6 etc. I will give it a go tonight and report back, thanks. I did suspect that it was a master / slave type issue and likely the MX but no clue how to configure it. By the way, nobody actually said what PCG is... I'll try the link from Andy.
Jack
Jackplug
- UK
- Posts 83
Peter, OK, sorry, I spotted it, PCG Product Configuration Guide. But can't find it on the site. Does it have all the ML 'How To' for using Beo 4 and / or BL1000. Getting it set up right is the first issue, but I'm a bit of a Multi Room virgin, having only just found, after 10 years of looking, an AAL cable (7 pin) long enough (20m) to bring an upstairs room into the mix. Not sure why I bothered to be honest... as my eldest daughter has a wall mounted BM3000 + CX50s fed by a nano... and I can't hear anything I play over the din from that anyway. I might be back at the weekend P.S. In case you're wondering why I didn't think to just get a long ML cable and done this before, well, the cable run is 20m almost as the crow flies, going through walls and floors too, which is easy with a round din plug on the end. Not so easy with the ML square plug. Plus, well, I just couldn't be bothered until now as I've had B&O in every room for years. Except that now, the PC (mp3s) are only connected to the BS2300 and so I want to access that from around the house, plus the AVANT Sky+ feed, naturally. Thanks again.
Jack
Peter
- Posts 9,572
To access the manuals you need to be a silver or gold member so I am afraid Andy's links are not going to get you there. Try Option 6 first and if not working, let me know. My system is pretty similar so I can play around with mine to check!
Jackplug
- UK
- Posts 83
Hi Peter, Well, I tried option 6, made no difference. So I've gone round and checked all the system devices and cables by using the 'half-split' method of using a good path then swapping in and out variious elements to maybe isolate a hardware fault. So I've done that, both Beoconverters are fine all ML and AAL cables are fine. So I'm back to the start. All the Audio operations work fine on the MX whether I put it in option 2 or 6. To try and activeate the AVANT via the MX I've been pressing either just V.TAPE or then LINK > V.TAPE etc So I'm not sure if the system is set up correctly but I'm just not pressing the right buttons in the right order. So I probably do need the PCG... By the way... I'm not against the idea of joining as a silver or gold member, just that I was a bit miffed to not have been able to get on the 'founder member' list as I had been using this site as far back as 2002 and did make a £15 contribution back then (before other founder members joined!), After all the changes to the hosting of the site, my account was lost...) I emailed 'Steve' admin but no reply. I'm not going to die in a ditch over it but will have a think about the potential benefits. My 'owners systems' contribution was made in 2003 (Jack USA). But I'm back in UK now, and I have a Beolink, on the Blink still :-)
Jack
Jackplug
- UK
- Posts 83
Peter, Could it be that I need to be using a Beolink Video box http://www.beoworld.org/prod_details.asp?pid=982 instead of the Beolink Converter for the MX? I thought that the Beolink Converter I have (type 1611 sw 1.3) would have done the same job as the former Beolink Video box??
Jack
Peter
- Posts 9,572
Try 2.6. PICTURE , 2, STORE then PICTURE, 6,STORE. On the founder member bit, this was at the starting of the site once Steve had sold it. There waqs a considerable amount of set up costs as well as the large amount the site cost. The founder status was granted to those who contributed at the outset to help with this. No money came from the previous incarnation - indeed quite the reverse.
PhilLondon
- London
- Posts 2,545
The Beolink converter works if there is a Hifi on the other side. For a TV you need a Beolink Video. I have one and it works fine.
Jackplug
- UK
- Posts 83
Thanks. So you're saying if I just swap out the Beolink Converter and put a Beolink Video in its place it will work. Is there anything I need to set up on the TV? And, once set, can I just then press 'LINK + V.TAPE' etc on the Link room TV and it will send those commands to the Master Video source (AVANT in this case). How does the Link Room (Zombie) TV then switch to the distributed RF coming from the AVANT modulator (which is currenlty wired in)? Next, has anyone got a Beolink Video for sale, they seem to be like Hen's Teeth, although I just saw one sell on ebay, doh! Also, anyone want a Beolink Converter going spare soon :-) Thanks for the help
Jack
BMGHB
- Joined on 05-12-2007
- Posts 219
************************* VIDEO SYSTEM SETUP **************************
BeoVision Avant 32" 100 Hz MKI (840x) SW 2.x
Connection Video Connect the aerial to the aerial input of the TV-set.
Selecting option on the TV-set Option: OPTION 2, with Beo4
Press: | Display: ------------------------------------------- STANDBY + LIST at the same time | OPTION? GO | V.OPT 2 | Observe confirmation | from BeoVision Note! If the TV is equipped with a Dolby Surround Module, the TV's default SPEAKER mode will be 3. This has the effect that the speakers of the Avant will not play stereo. To avert this, the TV Front Speaker Setup must be set to 'None'. This is effected via the menus Setup -> Sound -> Speaker. However, this is not possible on Avant 50Hz with S/W lower than 2.0
In case of interference between the modulator frequency and other signals in the UHF region, adjust the modulator frequency from the TV menu. Procedure: Setup / Tuning / Link Frequency When you have found the desired frequency, press (GO/PLAY) to save it. The recommended distance between stations in the UHF region is 16 Mhz. ************************* AUDIO SYSTEM SETUP ************************** Beosystem 2300
Connection Audio Connect the aerial to the aerial input of the audio master.
When using the remote control mute function, sound is restored by turning the volume up or down. Selecting option on the audio master Option: OPTION 0, with Beo4
Press: | Display: ------------------------------------------ STANDBY + LIST at the same time | OPTION? GO | V.OPT LIST | A.OPT 0 | Observe confirmation | from AudioMaster Software (S/W) 1.3, order No. 8342804, for Beosystem 2300 supports the Beo4 control, but the timer programming and 2-way IR have been removed. ********************* AUDIO/VIDEO/LINK SYSTEM SETUP ******************* Connection
A BeoLink Converter is required to be able to connect the video- and audiomaster, part No. 1161166/1161466
Connect the AUX/TV socket of the audiomaster to the BeoLink Converter's AUDIO AUX LINK socket using a 7/7-pin DIN cable. Connect the BeoLink Converter's Master Link socket to the Master Link socket of the TV-set using a BeoLink cable. Connect a POWER LINK socket of the audiomaster to the POWER LINK socket of the BeoLink Converter using a Power Link cable. Note! After installation and option programming or after a mains drop-out an audio source most be selected by means of close-up operation in order to obtain the correct A/V setup. The setup influences the A/V RECORD.
Audio sources are not switched off when switching to a video source, (out of courtesy to any users in local rooms). Balance, Bass, Treble and Loudness cannot be adjusted on the audio- master (a remote control terminal has to be used). However, adjustments will affect a Local Room, if any. Volume adjustments made on the audio- master can adjust audio sources but a display deviation may occur on the audiomaster. Close-up operated audio recording of video sources is not possible (use a remote control). No Audio Timer recording from 3-digit program numbers is possible, e.g. from the Satellite receiver in BeoVision. In some cases it may be necessary to apply a long standby pressure to switch off a product. A record player cannot be connected to the Beosystem when such a system forms part of an A/V setup. ********************* REMOTE CONTROL FOR MAIN ROOM ******************** The recommended remote control is Beo4
The following remote controls may also be used: Beo5 Setup for Beo4 remote control: Beo4's "LIST" must contain the following items in order to be able to operate the Main Room products. FORMAT STAND CLOCK LARGE REVEAL INDEX UDDATE MIX SUBCODE STORE MONO (changed to SOUND with S/W 4.0 or higher in Beo4) (RESET) AV (only with S/W 4.0 or higher in Beo4) See Beo4's operation manual page 10/12 on REMOVE and ADD functions from/to the List *************************** LINK SYSTEM SETUP ************************* Master Link
BeoLink Video Beovision MX 7000 IT Connection The aerial signal is distributed to the TV-set in the link room from the aerial output socket RF OUT on BeoVision in the main room.
Connect the Master Link cable to BeoLink Video's Master Link socket in the local room. Connect the TV-set's AUDIO AUX LINK socket to BeoLink Video's AUX socket using a 7/7-pin DIN cable. Setting of option in the Link room BeoVision: OPTION 6, with Beo4
Press: | Display: -------------------------------------------- STANDBY + LIST at the same time | OPTION? GO | V.OPT 6 | Observe confirmation | from the BeoVision Note! The audio master in the main room cannot distribute PC sources, e.g. N.MUSIC and N.RADIO to the Master Link system. The PC sources are therefore only local sources in this Link room
It might be necessary to change the frequencies of P.no. 46, 47, 49, 50 of the link room TV to the Avant VTR modulator frequency. On the Link TV it may be necesseary to modify the frequency for P. No. 60 to the modulator frequency of the Avant VTR. The following frequencies is programmed from factory. V.TAPE 1 599 MHz P.nr. 49 V.TAPE 2 567 MHz P.nr. 48 SATELLITE 599 MHz P.nr. 47 CDV 551 MHz P.nr. 46 LINK TV 599 MHz P.nr. 50 The following frequencies is programmed from factory. V.TAPE 1 P.nr. 60 599 MHz SATELLITE LINK TV CDV V.TAPE 2 P.nr. 61 567 MHz The frequencies of the link room TV must be changed as follows: Press: V.TAPE Disconnect the AAL cable from the link room TV Press: TV Tune the link room TV in to the frequency Store P.no Connect the AAL cable The frequences of the Link TV are modified as follows: Press: V.TAPE Press: MENU Select Setup / Tuning Tune in the TV-set on the frequency Press: GO to store the frequency. There are no menus on LINK TV-sets from external video sources. For example the main room's VTR or Satellite. No audio or video recording in the central room can be initiated from the local room. In some cases it may be necessary to apply a long standby pressure to switch off a product. ********************* REMOTE CONTROL FOR LINK ROOM ******************** The recommended remote control is Beo4
The following remote controls may also be used: Beolink 1000 Setup for Beo4 remote controle: Beo4's "LIST" must contain the following items to be able to operate the products from the Link Room. RANDOM REPEAT SPEAKER (only with S/W 1.3 or higher in the Audiomaster.) CLOCK LARGE REVEAL INDEX UDDATE MIX MONO (changed to SOUND with S/W 4.0 or higher in Beo4) (RESET) LINK V.SETUP (only with S/W 2.0 or higher in Beo4) AV (only with S/W 4.0 or higher in Beo4) See Beo4's operation manual page 10/12 on REMOVE and ADD functions from/to the List Note! CUE and SLOW on the VTR in the main room are operated from the local room with Beolink 1000 in the following way: CUE : SHIFT << or >> SLOW : SHIFT STEP UP or STEP DOWN
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
Jackplug
- UK
- Posts 83
Errr.... I thnk I owe someone a beer... (case of) :-) Ta Though, as correclty stated already, I need a Beolink Video not Converter to do all this. ... Dear Santa...?
Jack
Page 1 of 1 (17 items)
