Latest post 09-28-2008 5:06 PM by ujn2. 6 replies.
Page 1 of 1 (7 items)
  • 09-24-2008 4:39 PM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Beo 5 Icons not working correct. Looks good in the tool and mostly bad on the Beo5. What's wrong?
     I adjusted ALL my Icons to 92x92 pixel to work properly with the remote. On the screen of the config tool it looks good and after transferring it to the remote it looks ugly!
    I made a "help"-screen for my beo5 and this seems to be the ONLY screen where  the icons look like they should.
    Can somebody explain this?
    click photo for bigger view:
  • 09-24-2008 4:45 PM In reply to
    Re: Beo 5 Icons not working correct. Looks good in the tool and mostly bad on the Beo5. What's wrong?
    Icons must have 99(wide) x 44(height) pixels maximum.
    You will find lot of answers here
    Santiago
  • 09-26-2008 1:55 PM In reply to
    • ujn2
    • Not Ranked
    • Joined on 03-27-2008
    • Posts 17
    You can actually make them bigger here is an example, see attachment.
    If you do it on that way you can make some pretty cool design/layouts on your Beo5... I working on one, will upload it once it's finished!
    Edit: I think the 3 buttons on the left is 107x66 and then have 1 black pixel line on the left.
  • 09-26-2008 4:51 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Thanks for that tip!
    I actualy find out, too, that you can use bigger icons if you choose the 3x3 layout for a page. 100x44 needed for the 4x3 page layout.
    I'm looking forward to see your work :-)
  • 09-26-2008 7:09 PM In reply to
    • ujn2
    • Not Ranked
    • Posts 17
    I found out that for 4x3 grid:
    Bottom icons : 106x54 (1px black line in bottom)
    All other: 106x66
  • 09-28-2008 4:40 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    good job! Thanks. I'm experimenting with this to find the best layout design ..
  • 09-28-2008 5:06 PM In reply to
    • ujn2
    • Not Ranked
    • Posts 17
    It's posible to make some pretty slick designs, anyway post your results when they are done!
