Latest post 09-25-2008 10:58 AM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 09-24-2008 2:41 PM
    two way beolab 3500
    Hi!
    Is it possible to find a two way beolab 3500 of course with mcl
  • 09-25-2008 2:25 AM In reply to
    Re: two way beolab 3500
    The short answer is NO if you mean two way IR remote.
    The long answer is the Beolab 3500 came in two versions (well three if you include the LCS9000)
    1. The original version which had both MCL (Master Control Link) and ML (Master Link)
    2. The latest version which had powerlink sockets and can be used with the Beolink Wireless 1 and is the one sold today
    All versions of the Beolab 3500 are one way IR
    Look HERE for further information about the product
    Regards Keith....
  • 09-25-2008 10:40 AM In reply to
    Hi!
    Thanks for info.
    Can I find lcs9000 which is two way ir?
  • 09-25-2008 10:58 AM In reply to
    The LCS9000 is functionally the same as version 1 of the Beolab 3500 meaning ALL versions including the LCS9000 are one way IR
    Regards Keith....
