Hi there,
I have been offered a working BeoCenter 2300 for almost nothing. I'm new B&O's active speakers, has ontil now only being using the old BeoLab 5000, BeoMasters and passive speakers.
I'm wondering which speakers I should be using. My wife like the BeoLab 3, which I also can get second-hand to a resonable price. Would it make sence to use a BeoLab 2 together with the two BeoLab 3? Is that possible to make such configuration? Does that make sence?
How is the speakers connected? Dows the left+right signal run from the BeoCenter to BeoLab 2 and from here to the BeoLab 3? Will the BeoLab 2 remove the sub/low frequencies from the signal before sending it to BeoLab 3? Or does it work totally different?
Is there a guide available telling how all this modern stuff (PowerLink and active BeoLab speakers) works?
Regards Nis
