My new Beomaster 4400 has some minor problems. I'll open it later today, but as always, I thought I'd ask first...
First and worst, the other cooling fin on the right gets real hot. I suppose this is the output amp idle current being badly off, since I hear nothing wrong with the sound? Are the trimpots prone to go bad?
Secondly, the bass control doesn't work. I suppose the fork of the slider is broken...
And last, the Tape 1 selector doesn't reset the others, i.e I have to turn the receiver off first before going for example from FM to tape 1, otherwise both selectors stay down. Some common mechanical problem perhaps?
Edit: I did the unthinkable and read the user manual. Seems the last "problem" is by design
