Hello all.
Newbie here, but I've owned a BeoGram 2000 for ten years or so. I recently picked up a BeoMaster 5500, Beogram CD 5500, and MCP 5500, and I'm having trouble getting the 2000 to work. I'm not sure if they are not compatible, or if I'm connecting it improperly (or both!). I bought the 5500 due to the built in phono preamp. The 2000 has a 5 pin cable; it has an attachment to change that to an RCA. I tried using both, to no avail...then when I disconnected the RCA cable, I broke one of the wires! So if I need to use it, there is some soldering (or ebay-ing) in my future.
The 2000 worked fine with my previous setup, and the CD 5500 works fine with the BeoMaster. Any insight? I'm sure this has been asked, but I haven't been able to find an answer. I don't have a manual (maybe I should upgrade my membership), so I'm pretty lost.
Thanks in advance,
Marshall
