Don't tweak anything unless you are absolutely sure its needed. Trial and error won't get the tuning correct
If the supply voltage to the board is correct (battery voltage), there's really not much you can do without more advanced instruments.
Maybe it has a blown IF transistor or something like that. Sounds to me like a job for Tim...
