Hi Peter, I brought my AV9000 from Singapore. At the back of the TV is a switch which says PAL / NTSC. I tried both but it didn't make any difference.
During the tuning, I can either select B/G or L, but both seem to work the same. The TV will search for a channel and when it stabilizes, it will go to B/G and I will only get static.
There are a few other switches behind which read Frequency 559-639, Attenuator On/off. Record Level, NTSC Pal 4.43 60 Hz.
I have tried fiddling with all but they don't seem to make a difference.
Any other suggestions? Thanks so much for the responses so far. I really appreciate them.
