Latest post 09-29-2008 12:53 PM by TWG. 11 replies.
Page 1 of 1 (12 items)
  • 09-20-2008 4:08 PM
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    My shiny new Beo 5 is broken?
    Good evening,
    so yesterday I bought the Beo 5 and was very happy. I charged it yesterday afternoon and played with it about 20min between yesterday evening and today afternoon.
    Than I installed the software on a Computer with SIS-Chipset and the computer didn't recognized my Beo5. "Unknown USB-Device" (I hate Windows). Ok, I thought I'm gonna give it a try on my local PC tomorrow BUT my Beo 5 suddenly showed "Recharge Battery" and turned off.
    I turned  it on again and looked in the INFO-Menü: The Battery was empty.
    Is my Beo 5 broken? It was fully charged and I can't imagine that it looses that much battery  power in nearly 24h?
    Or could  the computer be the problem and the USB-Port discharged the Beo 5? But this would be a lousy construction on the Beo 5 side ...
    Any help? I'm not in a very good mood about my new toy :-(
  • 09-20-2008 5:44 PM In reply to
    Re: My shiny new Beo 5 is broken?
    No. It is a software issue and is fixed by updating the firmware - it needs to be 1.34a if it isn't already. Charge it overnight and see what firmware it has tomorrow.
  • 09-20-2008 5:56 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Hello Peter,
    the Beo 5 already has  Firmware 1.34a. My dealer did the update for me. This was the 1st thing I asked him ;-)
     Ok, I'm doing a complete recharge tomorrow and will try again (fingers crossing). Is there any way to "reset" (without losing data) the Beo 5?
    Thanks again
  • 09-20-2008 6:21 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi there.  I would charge it with the mains adapter rather than the USB connector.
    The charge from the USB is really slow.
    Andy T.
    Poor me, never win owt!
  • 09-20-2008 8:01 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    yep, I'm going to do so and I strongly hope that this isn't some kind of electrical design flaw from B&Os side ... :-(
    I'm gonna post tomorrow evening/night again when I'm at the office; oh and I'm legaly in the office, no burglar or s.th. like that ;-)
  • 09-21-2008 1:10 AM In reply to
    • Quim43
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Press for about 3 seconds the central button to turn the Beo5 off. Place the Beo5 on its charger and I think the PC will recognize it.
    You can also take a look Here Keith is doing a great job.
    Good luck
    Quim
  • 09-21-2008 5:29 AM In reply to
    Try charging it directly from the power supply and not with your PC's USB... if you haven't done so already...
  • 09-21-2008 1:25 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Hi, I've charged it via power supply for about 5h now, it's full and it was recognized on another PC that does NOT have a SIS chipset.
    BUT: Now the software tells me "Configuration version mismatch (Configuration version mismatch)" when I try to download the configuration to my Beo 5!
    B&O Configtool Software-Version: 1.02
    Beo 5 Software/Firmware: 1.34a
    Serializer Version: 0.35
    Could andybody send me a link to the newer B&O-software version via PN? I can't believe it because it worked when my dealer did it in the store :-(
    Thank you for your help.
    btw: Does "dimming" of the Beo 5 screen work for you? The screen fades black after e.g. 30s but does NOT dim after 10s?!
  • 09-22-2008 5:03 AM In reply to
    TWG:
    Hi TWG,
    If you want to watch the "dimming" feature effect, you must turn on the beo5 screen in an ambient brightly enough, like a really shiny day or directly under an artificial light, only then, the first backlight level is different from the dimmed one.
    Regards.
    Santiago
  • 09-22-2008 8:35 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
     thank you for the tip about dimming ... it's not broken ;-)
    actualy I tried configuration with the new software on another computer that does NOT have an SIS-chipset. Now it seems to work :)
  • 09-29-2008 2:38 AM In reply to
    TWG:
    If you have firmware 1.34a loaded into your Beo5 then ONLY version 1.30 Configuration Tool software or later will work. See HERE for further details
    Regards Keith....
  • 09-29-2008 12:53 PM In reply to
    • TWG
    • Germany
    • Posts 950
    • Gold Member
    Thanks, Now I have SW 1.30 on a NON SIS-Chipset computer and it works - how complicate is that? ;-)
