Latest post 09-20-2008 8:15 AM by BeoLad. 6 replies.
Page 1 of 1 (7 items)
  • 09-19-2008 1:55 PM
    BEO4 Sky+HD
    Do anyone have the BEO4 button mapping for the UK Sky+HD box
    If so could you please post it on here, I cant find anything for reference
    Jon
  • 09-19-2008 2:00 PM In reply to
    Re: BEO4 Sky+HD
    Hi i use V Aux to gain sky HD on my Beo 4 my box is connected to my Beocenter 6
  • 09-19-2008 2:25 PM In reply to
    Re: BEO4 Sky+HD
    Go 1 to 5 for the Sky menu's
    Up & Down arrow for scanning thru channels then Go Go to select
    Go Red to Copy ( usualy twice )
    Go 1 for Sky listings then Green for Planner/Recorded material ( the colour button functions are explained at the bottom of Go 1 listings page)
    There are a few more but that will get you started
    Richard
  • 09-20-2008 5:20 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: BEO4 Sky+HD
    go 6 gives you the option for subtitiles
    go up changes the chanel up / up on its own scrolls the banner
    go down changes the channel down / down on its own scrolls the banner down
    exit = backup
    stop = play / pause
    go 1 = tv guide
    go 1 + green = straight into sky plus planner
    go go = select
    go go + go red = copy program that is on the planner currently
    go 5 = info
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 09-20-2008 8:15 AM In reply to
    • BeoLad
    • Not Ranked
    • Joined on 07-23-2007
    • West Midlands
    • Posts 37
    Re: BEO4 Sky+HD
    Sky HD                                   Beo-4                             Link TV
    Select                                       Go Go                            Go Go
    Channel up                               Go ( up )
    Channel down                           Go ( down )
    TV Guide                                 Go 1                               Go 1
    Box office                                Go 2                               Go 2
    Services                                   Go 3                               Go 3
    Interactive service                     Go 4                               Go 4
    Information                               Go 5                               Go 5
    Help                                         Go 6                               Go 6
    Sky                                          Go 7                               Go 7
    Back Up                                   Exit                                 Exit
    Record                                     Go 8                               Go Red
    Play                                          Go ( hold )                      Go Blue
    Pause                                       Stop
    Stop                                         Go Stop
    Slow motion        Go Blue( hold )
    FFwd                                       Go >>
    Rewind                                     Go <<
    • BeoLad
    • Not Ranked
    • West Midlands
    • Posts 37
    Re: BEO4 Sky+HD
    Select                                       Go Go                            Go Go
    TV Guide                                 Go 1                               Go 1
    Services                                   Go 3                               Go 3
    Help                                         Go 6                               Go 6
    Sky                                          Go 7                               Go 7
    Back Up                                   Exit                                 Exit
    Record                                     Go 8                               Go Red
    Pause                                       Stop
    Stop                                         Go Stop
    FFwd                                       Go >>
    Rewind                                     Go <<
    • BeoLad
    • Not Ranked
    • West Midlands
    • Posts 37
    Re: BEO4 Sky+HD
    Select                                       Go Go                            Go Go
    TV Guide                                 Go 1                               Go 1
    Services                                   Go 3                               Go 3
    Help                                         Go 6                               Go 6
    Sky                                          Go 7                               Go 7
    Back Up                                   Exit                                 Exit
    Record                                     Go 8                               Go Red
    Pause                                       Stop
    Stop                                         Go Stop
    FFwd                                       Go >>
    Rewind                                     Go <<
