Latest post 09-20-2008 3:21 AM by BeoAffinity. 6 replies.
Page 1 of 1 (7 items)
  • 09-19-2008 11:49 AM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Beo 1 remote
    Will the BEO 1 remote work with a BV9?
    I'm ready for something new that I actually want to buy!
  • 09-19-2008 11:53 AM In reply to
    Re: Beo 1 remote
    i believe that is a negative.
    bc1 or bv1 only... someone correct me.
    • B&o bottle opener
  • 09-19-2008 2:23 PM In reply to
    Re: Beo 1 remote
    Yes! Only BC1 and BV1. And I think most unsuccessful remote from B&O.
    BTW relay  beautiful :)
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 09-19-2008 3:08 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beo 1 remote
    Agreed - pretty as in pretty useless. Get yourself a Beo4 or Beolink 1000.
    Chris.
  • 09-19-2008 3:43 PM In reply to
    • Ian
    • Top 500 Contributor
    • Joined on 04-16-2007
    • UK
    • Posts 132
    Re: Beo 1 remote
    Can you use a Beo4 on a TV (i.e. BV1 / BC1) that came with a Beo1?
    Ian
  • 09-19-2008 5:42 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beo 1 remote
    Ian:
    Ian
    Pretty sure you can select between Beo1 and Beo4 in the setup menu.
    CraigSmile
  • 09-20-2008 3:21 AM In reply to
    Re: Beo 1 remote
    I use a Beo1 as a simple remote (Radio on/off, volume) for a BeoSound 3000 via IRtrans (www.irtrans.de). It also possible to configure the the IRtrans module for using the Beo1 with a BeoVision system.
    Andy
