Latest post 09-17-2008 12:17 PM by linder. 5 replies.
Page 1 of 1 (6 items)
  • 09-16-2008 5:10 PM
    Beocenter 9500 Beogram 7000 question
    I received a Beocenter 9500 today that I purchased on Ebay.  The seller described it as in mint condition but it looks new as if was never taken out of the box.  I am really happy.  However I have a Beogram 7000 which of course had an inbuilt RIAA.   How can I turn of the RIAA in the Beogram 7000 and still use the datalink functions of the Beocenter 9500?
    Thanks,
    Bill
    Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002  BL11
  • 09-16-2008 5:28 PM In reply to
    Re: Beocenter 9500 Beogram 7000 question
    With difficulty! I would suggest swapping it either for a BG9500 or a BG5500.
  • 09-16-2008 5:32 PM In reply to
    You will need to cut through the legs of a couple of capacitors to disable the pre amp. Then you will need to change the datalink in the din plug from pin 7 to pin 5 ( or the other way!) as non RIAA systems expect the datalink on a different pin.
    All in all it's better to sell the 7000 and buy a Beogram 9500 or similar!!
    Regards Graham
  • 09-16-2008 6:14 PM In reply to
    Thanks for the responses.  I guess I will have to start looking for a Beogram 9500.  My Beogram 7000 is in mint condition which will be easy to sell.
    Regards,
    Bill
  • 09-17-2008 1:45 AM In reply to
    Should be quite easy as the Beogram 7000 is probably the most sought after deck as it will work with all the modern equipment. Also very modern looking.
  • 09-17-2008 12:17 PM In reply to
    Peter you were right.  There is a lot of interest in a Beogram 7000.  I have already received several emails asking about the price.  I probably should have added that I will not be selling the Beogram 7000 until I find a suitable Beogram 9500.  The BG7000 works fine in the AUX connector.  It is a US version.
    Thanks for everyone's help.
