1st March February 2012
Latest post 09-17-2008 2:07 PM by kallasr. 5 replies.
09-15-2008 7:54 AM
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Wall mount for Beosystem 3300
I have a wall mount for the Beosystem 3300 for sale, but I cannot see how the upper part is part of the system. Are just the two lower one need to hang up a beomaster 3300, beogram cd 3300 and beogram 3300? Where can I find a manual for the assembly? Thanks Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
kallasr
- Posts 1,077
Re: Wall mount for Beosystem 3300
Sorry for putting this in the wrong section... If an admin could move this to the general forum? Thanks! Ralf
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Moved to the General Forum.
Ignace
- Moderator - NL
- Posts 2,749
kallasr:I have a wall mount for the Beosystem 3300 for sale, but I cannot see how the upper part is part of the system. Are just the two lower one need to hang up a beomaster 3300, beogram cd 3300 and beogram 3300? Where can I find a manual for the assembly? Thanks Ralf
Hi Ralf, the 2 long parts are for the Beomaster and Beocord, which are mounted vertically.
The smaller bracket is mounted horizontally and is for the Beogram CD / Beogram.
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
Hi Ralf The upper part you are refering to in your photograph is not used to support the products in any way. It is simply a fin that covers all of the cable connections which are on the back of the BeoMaster 3300. Once the bracket is mounted to the wall and you have hung the products on the bracket, you then slide the cover on top so that none of the connections are visible. Opman
kallasr
- Posts 1,077
Thanks a lot! This helped me understanding how to set this up. If I don't get the wife's GO for another system (on the wall that is), I will sell this one, shipment will be an issue, since this is really a long package. Ralf
Page 1 of 1 (6 items)
