Latest post 05-13-2007 1:20 PM by Peter. 2 replies.
Page 1 of 1 (3 items)
  • 05-13-2007 1:07 PM
    Link Room
    Dear All: I took the plunge and became a Gold member.  It was a gift to myself for passing a grueling set board exams and also to support a site that gives me great insites and pleasures--Learning what other members across the pond are doing is great fun.  Not to mention that music plays a great part in my daily life and B&O makes a 'lazy' audiophile enjoy music at its finest without the 'hi-fi' burden.
    What do I need to link a room?  The goal is to link my BS 9000 to a pair of BL 3s in the lower level.
    Any help is greatly appreciated.
    Dario
    PS.
    I would urge others to support a fantastique site that will only get better with time.
    When I hear music, I fear no danger. I see no foe... Thoreau
    Filed under:
  • 05-13-2007 1:14 PM In reply to
    Re: Link Room
    Welcome.
    By lower level, I assume you mean in another room downstairs?
    If so, I believe you need a Beolink Active. This would give remote control of the BS9000 from the lower level with independent volume control.
    Regards Graham
  • 05-13-2007 1:20 PM In reply to
    Re: Link Room
    Rather depends on how you want to do it. The conventional way would be to get a Beolink Active and wire to the link room using ML wire. That would be my choice. You would get a small round Infra Red eye, about the size and shape of a hockey puck and a black box which the speakers would attach to which can be hidden.
    The alternative is to use a Wireless connection - look at Wireless 1 in the products range. No picture there but will try to get one. I will also put the user manual up as soon as possible! (Manual now on!)
    Thank you for subscribing and I wish you luck in the draw!
