Hello! My first post on this forum...
I'm putting my father's Beogram 1000 back into service after a 20-plus year layup. It's a model 5203, with the round motor, 3 speeds and the chrome speed change control. When I first fired it up, it ran fine at 33 and 45, but stopped turning when I selected 78. It stayed not turning when I went back to 33, but gentle clockwise pressure on the control got it going again. It plays fine at 33 (and sounds good: gives my modern Rega a run for its money!), but won't run at all at 45 or 78. The fine adjust is siezed as well.
As far as I can make out, it's the drive belt tension that pulls the idler wheel against the motor spindle. The arm with the idler wheel moves easily, and the speed change mechanism appears to work fine. However, I noticed that the drive belt seems very slack, and I'm guessing this is the main problem - although I'd have expected this to be worse for 33, since this is the smallest-diameter part of the motor spindle (I think?). Can anyone advise me on this, please? Plan A is to source and fit a new drive belt, cleaning up the rubbery deposits from the motor spindle and pulley before I fit it.
What I can't figure out at all is the fine speed adjust. I can see the control spindle, and a wire with a tensioning spring joining its two ends together, which runs round a pulley and attaches to a lug on a kind of brass ring that runs around the motor spindle. My guess is that rotating the control spindle causes the brass ring to rotate, but I can't figure out how that alters the speed. In my case, I can't move either the control spindle or the brass ring. Can anyone advise me how to set about freeing this up, please?
I also noticed that the motor runs quite hot, enough to warm up the shelf that the deck is sitting on. Is this normal? I can hear a very small amount of noise if I put my ear right next to the deck, but I can't tell if it's motor noise or belt/pulley noise. The motor spindle spins very freely with no noise or stickiness, so I think I've escaped the curse of dried-up bearings.
I'd be grateful for any hints and tips that you folks out there can give me!
