Latest post 09-14-2008 6:35 AM by Calvin. 3 replies.
Page 1 of 1 (4 items)
  • 09-13-2008 11:18 PM
    • bus55
    • Not Ranked
    • Joined on 12-23-2007
    • Posts 10
    MCP 5500
    Hi there just wondering if theres a way of keeping the display panel of my master control panel illuminated constantly while the system is playing instead of it switching off after a few seconds. thanks again.
  • 09-14-2008 2:23 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: MCP 5500
    Not to my knowledge.  I find them to be big battery drainers as designed.
  • 09-14-2008 3:21 AM In reply to
    Re: MCP 5500
    I think you would need to change the batteries every day  if you found a way to do it!
    Simon
  • 09-14-2008 6:35 AM In reply to
    • Calvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • London
    • Posts 233
    Re: MCP 5500
    I suppose you could maybe build a MCP into a table, wall, piece of furniture etc and wire it to the mains and a transformer.  I've always thought it might be cool to have one built into the wall when you got into an apartment
