1st March February 2012
Latest post 09-15-2008 11:53 AM by BenSA. 7 replies.
09-12-2008 5:49 AM
ChrDH
- Joined on 04-16-2007
- Denmark
- Posts 493
Beomaster 3500 worn't store new soundlevel, dead button?
Hi There I have a bit of a odd problem. The store button on the glass-panel of my new Beomaster 3500 seems not to work. It is not responding when i try to store a new sound level on the beomaster. Is it common that buttons fail, or could it be a circuit-problem inside? The goto-button next to it works just fine. Thanks
Best regards Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
Re: Beomaster 3500 worn't store new soundlevel, dead button?
ChrDH:Hi There I have a bit of a odd problem. The store button on the glass-panel of my new Beomaster 3500 seems not to work. It is not responding when i try to store a new sound level on the beomaster. Is it common that buttons fail, or could it be a circuit-problem inside? The goto-button next to it works just fine. Thanks
Same on my 4500 together with the 'sound' button. However I find that all the settings including 'store' can be controlled via my Beo4. Can you use this to achieve what you want?
ChrDH
- Denmark
- Posts 493
Yes, thanks for that reply, that means my beomaster probably will do as told, but throug a beolink/beo4. I'll bring a beolink 1000 with me to Work on monday and test if i can store using the remote instead of the glas-panel buttons. Best regards Christian
ChrDH
- Denmark
- Posts 493
By the way, a paper-clip makes a great areal for FM-reciving... Chr
ChrDH
- Denmark
- Posts 493
It works just fine storing volumen and stations with a Beolink 1000, thanks Christian
ChrDH
- Denmark
- Posts 493
ok, thanks, I'll try that. How do you slide out the glass panel?
BenSA
- Durban, South Africa
- Posts 808
You will see a small hole on the front of the BM, just under the glass. Insert a Paper clip (many uses obviously lol!!) or something similar in the hole which will push a clip down. With the paper clip still in the hole slide the glass to the left. It will the only slide a certain amount, it won't slide the whole way out. You can then lift the whole panel up, you might have to jiggle it a bit. You then need do undo a screw the holds the board on to the glass and then unclip the board from the glass, it also slides but to the right. You can wipe the inside of the glass with a clean damp cloth. You will see the sensors on the board. Check that the sensor that isnt working is not dirty or blocked. Then slide the board and glass back together. You can then test to see that they are all working before sliding the panel back onto the BM. Don't forget to put the screw back. Hope you come right!
Page 1 of 1 (8 items)
