Latest post 09-13-2008 11:48 AM by nobby. 8 replies.
Page 1 of 1 (9 items)
  • 09-11-2008 3:30 PM
    Problem with Beovision 3
    I have a 28" Beovision 3 I have not put it on for a couple of weeks.Instead of asking for the "Code" which we have in the same place ie top middle the word  "WAIT" comes up for a few minutes then it turns the TV off. Any advise!
    Filed under:
  • 09-11-2008 5:03 PM In reply to
    Re: Problem with Beovision 3
    It's because there bin used a wrong pin code 3 times. you have to wait 3 h with the TV in standby.
  • 09-12-2008 5:52 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    The Stig - ver. 1.7:
    Since I purchased my 32" Beovision 3 it has always been used so I have not experienced this 'problem'. BUT, just in case it happens to me, how do I obtain/determine my PIN?
  • 09-12-2008 8:29 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    The vendor should have given this to you....if bought used. In case you got a from a dealer, it might not have been set or activated.
    If it was not activated/set you can set it in the service menu, Beo 4: Menu, Setup, 0, 0, GO (as far as I remember).
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 09-12-2008 4:20 PM In reply to
    • Kokomo
    • Spain
    • Posts 618
    It was bought new and I don't have any PIN. Thanks Ralf for your information, much appreciated.
  • 09-13-2008 4:09 AM In reply to
    Early BV3 do not have pin code.
  • 09-13-2008 7:32 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    BEOKNOW:
    That wil explain why I followed the advice given above and it didn't work! Thanks for that.
    I did come across 'Theft Protection' though which is shown as 'on'. How does this operate?
  • 09-13-2008 7:55 AM In reply to
    I have a BeoVision 3.  Went to turn on yesterday and we can't get it past stanby.  The control works ok as the settings appear in control window still.  This is really frustrating because you can't switch it on manually either!  Please help.
  • 09-13-2008 11:48 AM In reply to
    Its possible that it has developed a fault and wont come out of standby to avoid further damage to the set.  Where are you based ... someone on beoworld may be able to help.
    Neil
