I had the same problem for ages before I worked that one out. As far as I can tell, the Timer Off means that one of the sets of speakers are muted when you set the timer (ie for if you wanted your 5500 to only pipe music into you bedroom in the morning, not your living room)
It seems a silly way to "say" it though. 'Timer Mute' would give a better description of the function
