Latest post 05-13-2007 6:17 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 05-13-2007 6:04 AM
    Masterlink module for beocenter 1
    Is it difficult to install this yourself?
    Is it the same 4015 as used for the BC6?
     are there modules secondhand?
  • 05-13-2007 6:17 AM In reply to
    Re: Masterlink module for beocenter 1
    Not difficult to install but expensive ~£150!!!! Not sure whether other modules will work but you could check the part numbers with your dealer or the service manuals on this site.
    I would imagine they are as rare as hens teeth secondhand.
    Regards Graham
