Does anyone uses the IR to BR converter from http://ir2bt.com/ ?
If so, what are the experiences?
I have it, but buy this instead: http://www.schmartstuff.com/
You can flash FW by ourself when it´s been change
http://tv4play.se/nyheter/lokala_nyheter/halland?videoId=1.645093
I thought I read in another thread (http://forum.beoworld.org/forums/post/100896.aspx) you weren't satisfied with the schmartstuff?!
Do you have the most expensive one, the pro-version?
Can you tell something how to install it, assuming you have the pro-version.
Doc:I thought I read in another thread (http://forum.beoworld.org/forums/post/100896.aspx) you weren't satisfied with the schmartstuff?!Do you have the most expensive one, the pro-version?Can you tell something how to install it, assuming you have the pro-version.
Pro version - yes
Yes that is true, but no they have come with new SW and it work pretty great. That means that ON/OFF works but the other command works aprox 80%. If you use Nyko it works 100% BUT no ON/OFF.
You pair it like a blueray remote - very easy
Hmmm, "works aprox 80%", and they claim on their site it works with all 31 commands.
Which "20%" do you miss / isn't working?
mr_anders_son:I have it, but buy this instead: http://www.schmartstuff.com/
Hmmm sounds interesting, but was wondering, If I decided to get this item, what STB would I set the PS3 to be in the BV7 connections menu.
JoC: mr_anders_son:I have it, but buy this instead: http://www.schmartstuff.com/Hmmm sounds interesting, but was wondering, If I decided to get this item, what STB would I set the PS3 to be in the BV7 connections menu.
NO not PS3 it´s only for Nyko IR Remote. You skall use Sony Generic DVD. Your dealer can make a PUClist for and flash BV7
