Latest post 09-06-2008 12:06 PM by j0hnbarker. 8 replies.
Page 1 of 1 (9 items)
  • 09-05-2008 1:12 PM
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Random sampling, or is B&O's way do-able?
    A long time ago, it was written....
    This is interesting, the global plamsa market is worth $10bln for 2008 and panasonic( which is he base of the bv4 )have a substantial slice of that.  Please explain the procedure that Bang &Olufsen use when 'selecting only the top2% of panels in a factory that produces many millions of units a year?? do they send a man in a white coat- well take 'that one'??
    Yesterday, it was written....
    Pioneer's top of the line Elite Signature Series Kuro plasmas are finally officially priced and shipping, ... At 2.5-inches thick, these panels -- hand selected for the deepest blacks and accurate colors --- will fit anywhere you'd like to have them installed, and each unique serial number gives access to a Pioneer website for that specific monitor's certified factory white balance setting.
    Ray
  • 09-05-2008 5:07 PM In reply to
    • Calvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • London
    • Posts 233
    Re: Random sampling, or is B&O's way do-able?
    Might be totally wrong, but I would have thought they maybe just ran a separate production line with a tighter set of specifications.  Running one costs more money (due to more expensive tooling and also rejects) but obviously this is not as large a concern for B&O
  • 09-05-2008 5:27 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Ray,
     Are you saying that Pioneer are now claiming to do the very thing which B&O were previously said, in these very forums, to do?  This is a bold statement, Sir, as those here who previously upheld such a claim were roundly thrashed (one hesitates to say castigated) for saying so.
    Tread carefully my friend.
    Russ
     PS>  The serial number calibration look-up is kinda nice though, in case you forget to look on the back before hanging the TV.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 09-05-2008 6:07 PM In reply to
    Are there any other comparable manufactured goods production processes where a certain percentage of the run is top-sliced and held up as a premium? I don't understand how this is supposed to work...
  • 09-05-2008 7:22 PM In reply to
    There has to be some minimal test performed on each panel which could single out both general faults as well as quality grades in order to funnel them through to the various brands which build off the panels. It's obviously built into the "plan" as Pioneer was able to jump on the BeoWagon with very little trouble and buy the way we've been buying for years.
    I also know that whatever happens at the Matsushita factories cannot be fool proof as we send back a certain percentage for credit once we put them through out testing process in Struer. I'm guessing that Pioneer has some similar process when they put their panels through the paces.
    While it may seem mind boggling to assess such vast production streams, much larger industries (food, pharmaceuticals, textiles, etc.) keep very tight control over their products. I think, with an understanding of industrial infrastructure, that it is actually more difficult to imagine that these plasma panels don't undergo scrutiny sufficient to categorize and rate them.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 09-05-2008 7:52 PM In reply to
    • symmes
    • Freedonia
    • Posts 290
    What happens when Matsushita starts making Pioneer panels, as well?  Will there be TWO people in white coats fighting to see who gets the good ones?
  • 09-06-2008 5:17 AM In reply to
    TripEnglish:
    Mmm. You'll have to forgive me for being a little sceptical Trip.
    I wonder if VW do the same thing with the running gear for their Phaeton and the Bentley Continental Flying Spur, with the 'premium' assemblies going to the Bentley production run??
  • 09-06-2008 8:08 AM In reply to
    • Russ
    • Posts 641
    JB,
    while the VW/Bentley analogy is OK, I don't think it's a precise match for this issue.  Although based on the same foundational 'architecture', the Bentley pieces are usually built to a different specification than the VW ones, so they aren't intended to reult in identical products.
    Think more about Intel producing dozens of 'identical' chips on a single slice of silicon...then after the fact discovering which ones don't work, and then runnung stress tests on each unit to determine the highest reliable clock speed for each of the rest.  In theory at least it is possible that a 2.0mhz chip and a 2.3mhz chip came off of the same slice.  Some variation is expected, planned for, and sold as such.
    Russ
    PS>>  In the old days at Aston-Martin, it was said that if you knew what to listen for, one could tell which of 4 different mechanics had assembled each engine from the exhaust note alone.
    McLean, VA USA
  • 09-06-2008 12:06 PM In reply to
    RussR:
    JB,
    Russ
    ...or you could simply lift the bonnet and look at the plate with the name of the specific mechanic that built the engine stamped on it.
