Latest post 09-05-2008 12:43 PM by saf. 6 replies.
Page 1 of 1 (7 items)
  • 09-05-2008 7:34 AM
    beosound 9000
    Hi Guys
    I am looking for the serial number on my beo9000 asi am thinking of selling it.Can anyone tell me where it can be found
  • 09-05-2008 7:44 AM In reply to
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    Re: beosound 9000
    Behind the control panel, you must take off.
    DU BEAU, DU BON, DU BO.
  • 09-05-2008 7:49 AM In reply to
    Re: beosound 9000
    Hi Thanks for that.............which part of the control panel comes off can i find a picture anywhere so i do not  damage it,
     Many thanksConfused
  • 09-05-2008 7:59 AM In reply to
    • Sal
    • Top 200 Contributor
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    Re: beosound 9000
    If you flip open the grated metal portion of the BS9000 which exposes the control panel, on the one short side of the panel, you'll see an indentation (for a finger). The control panel, which is held in place with strong magnets, just pulls off.
    I'd suggest firmly pulling up, and you'll notice that, the control panel tilts off the BS9000. When replacing the control panel, make sure that the side toward the center of the Beosound 9000 gets inserted first, there are short "prongs" into which the control panel needs to slide into, and flip back into place.
    Good luck!
    Love B&O, but no longer addicted.
  • 09-05-2008 8:03 AM In reply to
    Re: beosound 9000
    many thanks.................... how is the weather over there?
    As usual its raining in the good old U.KStorm
  • 09-05-2008 9:02 AM In reply to
    • Sal
    • Indianapolis, USA
    • Posts 261
    Re: beosound 9000
    Glad it worked out for you! :-)
    It's raining over here as well, we're getting the last bits of what is left of hurricane Gustav here in Indiana!Storm
  • 09-05-2008 12:43 PM In reply to
    • saf
    • Joined on 04-17-2007
    • Posts 458
    Re: beosound 9000
    Neat description, Sal. Actually, I find it a nice feature, too, if you insert the control panel the other way in (turning it 180 degrees) you'll notice that the characters displayed on the BS9000 will be 'upside-down', allowing for other placement options to give meaning, indeed. Fantastic - in my own little world! Smile
