Latest post 09-04-2008 1:38 PM by apearce. 2 replies.
Page 1 of 1 (3 items)
  • 09-04-2008 1:24 PM
    Help with Beo4
    Hi All,
    Does anyone know how i can assign on of the source buttons on my beo4 to a-aux? Or is there a way to get that source in the list or option menu? I can't seem to figure this out.
     Thanks,
    Ash.
    Beosystem 3, Beosound 4, Beolab 9, Beolab 3, Beolab 8000
  • 09-04-2008 1:35 PM In reply to
    • Sal
    • Top 200 Contributor
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    Re: Help with Beo4
    Unfortunately, you can't have A.AUX correspond to any direct single click on the source buttons, but you can easily add it to your "LIST" menu items by accessing the ADD function on the Beo4 (I'm at work, so if I get this wrong, please anyone, correct me).
    Press LIST/STANDBY to access the Beo4 Function screen, press UP or DOWN until you see ADD, then press GO, then press UP or DOWN until you get to AAUX, then press GO, and then press EXIT and you're done.
    -Sal
    Love B&O, but no longer addicted.
  • 09-04-2008 1:38 PM In reply to
    Re: Help with Beo4
    Can't believe i didn't pick that up, i think i've been staring at the remote for too long.
    Thanks very much for your help Sal!!
