Latest post 09-05-2008 9:14 AM by Steve at Sounds Heavenly. 2 replies.
Page 1 of 1 (3 items)
  • 09-04-2008 9:11 AM
    • BEOfreak
    • Not Ranked
    • Joined on 04-17-2007
    • Odense, Denmark
    • Posts 63
    Alternative to Powerlink mrk3 cable?
    Hi everybody,
    I'm looking for a (cheaper) alternative to Powerlink mrk3 cable, is the an alternative or do I have to go for the (expensive) original B&O or BOSSCOM cabel?
    Best regards
    Rasmus
    Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
  • 09-04-2008 1:58 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Alternative to Powerlink mrk3 cable?
    I wouldn't really want to go for anything cheaper. If anything, I'd see if you can get some 8/8 PowerLink (the kind supplied with BeoLab 5s).
     Weekly top artists:
  • 09-05-2008 9:14 AM In reply to
    Hi Rasmus,
    If you look on eBay, you will see that there are now several other brands of cable available that are compatible with Powerlink mark 3, other than B&O and Bosscomm.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
