Latest post 09-05-2008 9:16 AM by Steve at Sounds Heavenly. 4 replies.
Page 1 of 1 (5 items)
  • 09-04-2008 5:34 AM
    • Muhl
    • Not Ranked
    • Joined on 10-04-2007
    • Posts 12
    How to Connect MP3-player to beolab 8000
    Hello
     How do I connect my mp3-player to a set of bl8000s?
     Regards Muhl
  • 09-05-2008 2:41 AM In reply to
    • Muhl
    • Not Ranked
    • Posts 12
    Re: How to Connect MP3-player to beolab 8000
    Anyone?
  • 09-05-2008 5:02 AM In reply to
    I looked at doing this to my pair of BL3's, i had to buy two Powerlink to male RCA (part code 6270856), one for each speaker which then connected into a cable US sound adaptor cable (part code 6270433), which basically has two female RCA cables on one end and the headphone end that goes into the iPod or similar MP3 player.
     In the end i bought a 3200 and then bought a Powerlink to headphone jack off ebay which connected straight into the 3200, a much better solution however if i could do it over again i would have bought the BS4.
    If you're in the UK i have the sound adaptor cable however only one of the powerlink to male rca, which i'd be happy to sell, so you'd need to get another one powerlink to male RCA.
    Beosystem 3, Beosound 4, Beolab 9, Beolab 3, Beolab 8000
  • 09-05-2008 5:03 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Line-in  (Cinch/RCA)?
    If you MP3 player has an adapter cabel to Cinch/RCA, this would be the easiest way, but....
    I am not sure, if the BL will power on and off with the player's signal.
    Better would be to get a Beomaster/Beocenter with Powerlink and hook your player up to the TAPE socket.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 09-05-2008 9:16 AM In reply to
    Hi Muhl,
    Here is a cable that will do what you need:-
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=110285863270&ssPageName=STRK:MESE:IT&ih=001
    Just switch your Beolab 8000's to "Line" and (very important!) turn down the MP3 player volume first!
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
