Latest post 05-13-2007 8:32 AM by The Beonic Man. 3 replies.
Page 1 of 1 (4 items)
  • 05-12-2007 6:39 PM
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Updating Products on Beoworld
    Is there a link that I have missed to enable corrections to be made / sent to someone to correct the listing of product specifications?
    I am about to move my RL140s (bought new when first released in 1986 Smile) and wanted to find the weight and size.  I decided it would be easier to have a quick look on the web site as I was at my PC.  However the size seemed all wrong and the frequency response plus crossover details did not match up with my recollection.  I think the specifications against RL140s are for RL 45s!
    The size should be 70 x 50 x 24, weight 15kg and respone 40-20,000 +4 - 8db
     Whilst on the subject of help  - I have photographs of the brackets used to fix these to the walls but do not know how to send them so another member can see them.  Please help.....Confused
  • 05-12-2007 8:28 PM In reply to
    • Tom
    • Top 25 Contributor
    • Luxembourg
    • Posts 3,175
    Re: Updating Products on Beoworld
    send your data to one of our moderators (via PM), Lee or Steve, they sure can upload the changes...
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-13-2007 3:52 AM In reply to
    Actually send them to either Lee or Peter as we are doing the uploads. There are errors as these are from the old site. I am happy to change things. If only RL140s were as light as RL45s! Laughing
  • 05-13-2007 8:32 AM In reply to
    A note to moderators...
    You may be interested to know that the information for BV5 also needs updating. The current information is repeated several times and is also wrong, it refers to the non-HD BV5's not the HD versions.
    Simon.
    "We can rebuild him. We have the technology." 7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
