For all the US Beovision 8 owners out there... Can you enlighten me on some basics of TV operation?
Since the US BV8 has no internal tuner, what exactly happens when you press "TV" on the Beo4? Does it get programmed to one of the AV connections on the back panel? Or, when you want to watch lets say cable TV which is connected via a cable box to one of the back panel connections, do you press another button on the Beo4?
I apologize for the simplicity of the question, but since the BV8 has no internal tuner, what would pressing TV do? Ideally (I hope this is the case), I can program the BV8 to operate my TivoHD by pressing TV alone, and all the Beo4 keys can be mapped to TivoHD operation.... OR would the "TV" button be of no use to BV 8 owners?
Thanks, and the wait continues!
									    Love B&O, but no longer addicted.
