Latest post 09-03-2008 6:48 PM by Tom. 4 replies.
Page 1 of 1 (5 items)
  • 08-29-2008 2:10 PM
    • ProGram
    • Top 500 Contributor
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    Beocom 6000 kein Tastenton?
    Hallo!
    Ich habe seit einigen Tagen ein Beocom 6000 (ohne Headsetanschluß), bei dem es mich stört, daß ich keinen Tastenton habe. Nur beim Drehrad gibt es eine Rückmeldung. Kann man das nicht einstellen? In den Menüs finde ich da nix, gibt es vielleicht eine Tastenkombination, mit der man das einschalten kann?
    Gruß
    Chris
  • 09-03-2008 3:10 AM In reply to
    Re: Beocom 6000 kein Tastenton?
    Chris,
    If you are hearing clicks when you turn the dial, then we must assume the battery is fine because the click noise comes from the speaker. If there is no display or dialtone when you press the handset button, then the phone almost certainly has a fault. If this is the case a replacement PCB would be required. However, if this is a Mark II version which has a handset socket at the top of the phone, then you may wish to press and hold the centre dial button for at least 3 seconds, then do the same action a second time and see if the phone comes back to life.
    Regards Keith....
  • 09-03-2008 4:07 AM In reply to
    • ProGram
    • NRW, Germany
    • Posts 145
    Hi Keith,
    thanks for your reply. There is no Headset-connector at the top and the telefone works properly. It is only the fact, that I can't hear any keyclick, when you press a key (although it works). Only the wheel sounds. Many other telephones and especially cellphones have this option. Strange!
  • 09-03-2008 4:53 AM In reply to
    Sorry, I misunderstood your question. Its clear that I need to go back to school to improve my german.
    The only clicking you will get on any Beocom 6000 is with the dial.
    Regards Keith....
  • 09-03-2008 6:48 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Hab die Dokumentation noch mal schnell durchgelesen, doch nichts gefunden. Ich denke bei der BeoCom6000 muss man ohne Tastenton leben. Habe ihn jedoch auch noch nie vermisst...
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
