Latest post 05-13-2007 3:49 AM by beofreeman. 2 replies.
Page 1 of 1 (3 items)
  • 05-12-2007 1:12 PM
    De Toma X 501
    Hello,
    Does anyone have any knowledge of the De Toma x 501 digital decoder.
    I need to get hold of set of instructions in English, saving that the company address so I can contact them directly.
    Any help would be greatly appreciated.
    Thanking all in advance.
    Regards
    Peter
  • 05-12-2007 5:25 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: De Toma X 501
    beofreeman:
    Hello,
    Regards
    Peter
    Hi Peter,
    Welcome to BeoWorld Smile
    Member new020 has this DeToma decoder,
    and we have been in contact about connections, use of the correct types of Powerlink-cables
    (when used with Beolab speakers with display), and other issues / setup.
    Perhaps you could give some details about which B&O products & other products you would like to connect.
  • 05-13-2007 3:49 AM In reply to
    Re: De Toma X 501
    Hello Iggy, and thank you for your welcome to BeoWorld,
    I am using the decoder to connect my Pioeneer plasma to my system as follows:
    Beosound 9000
    Beolab 8000 x 2
    Beolab 7.1
    I will be adding other speakers at a later date.
    The issue I am having seems to lie with the decoder in that It it does not stay on. I hope the fault lies with the third party power unit, if it's not then who knows.
    Any help from you or New member020 is appreciated.
    As a new member myself I am not fully aware of this forums protocol , would you kindly conatct new020 on my behalf or should I and if  so how?
     Many thanks,
    Peter
