Latest post 09-02-2008 8:51 AM by kallasr. 15 replies.
Page 1 of 1 (16 items)
  • 08-28-2008 10:14 PM
    mounting system for the beosystem 4500
    does anyone know anything about mounting the 4500 system with wall mounts?  i need to know how the brackets attach to the system on the back?  also will i need the covers for the wires on the now top of the unit or will i be able to hide them behind the unti once it is attached?  thanks so much in advance for all advice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 08-29-2008 5:11 AM In reply to
    Re: mounting system for the beosystem 4500
    The brackets are fixed to the wall and the units simply attach onto the hooks on the wallbracket.  The beomaster has a longer bracket than the cd/beocord.  Measure the wall up and the brackets before you start drilling! They are a but fiddly to get right but check and check again.
    With regards to the cable covers, these have been on ebay recently, and for a decent price but are hard to get hold of.
  • 08-29-2008 6:02 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Actually, the bracket for the Beomaster is the same as for Beocord and Beogram CD, only they are attached different.
  • 08-29-2008 6:18 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    The image shows a wall bracket for components of Beosystem 4500 (and 3500)
    Beogram CD 4500(3500) and Beocord 4500 (3500) are mounted with the bracket attached to the wall as shown above.
    With Beomaster 4500 (3500), the vertical parts are placed on the sides (the other openings in the bracket)
  • 08-29-2008 8:08 AM In reply to
    hey thanks for the reply!  and the speed!  so the bracket that attaches to the back of the unit doesnt really attach to the unit ? is that right?  it just sets inth openings?
    thanks again!
  • 08-29-2008 9:19 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    The unit "hangs" on the 2 small hooks of the bracket.
  • 08-29-2008 11:23 AM In reply to
    • Mohawk
    • Top 500 Contributor
    • Joined on 01-30-2008
    • Sweden
    • Posts 103
    • Gold Member
    Hi
    If you wall mount your system take it as a good routine to check the glasspanels now and then. It has happened that the glue gets weak with time and the panel can fall off in worst case. Normally it's no problem - but it's good to know.
    /Fredrik
  • 08-30-2008 12:16 AM In reply to
    thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 08-30-2008 2:02 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Or you just mount it to a wooden 'plate' as the following picture suggest (and it did work, too)!
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 08-30-2008 2:03 PM In reply to
    • kallasr
    • Posts 1,077
  • 08-30-2008 2:05 PM In reply to
    • kallasr
    • Posts 1,077
  • 08-30-2008 2:06 PM In reply to
    • kallasr
    • Posts 1,077
    (all the ... just to trick the upload system...)
  • 09-01-2008 8:57 PM In reply to
    hi there did you mount your system to the boards in the picture?  ive decided i just like it sitting on top of a small entertainment system i do have the riser feet for the back of all the units so it still looks nice!  but can you just mount on the boards?
  • 09-02-2008 2:36 AM In reply to
    • kallasr
    • Posts 1,077
    Yes, just one board (for BM, BG CD, BC).
    Ralf
  • 09-02-2008 8:16 AM In reply to
    thats great thanks again! im gonna give it a try
  • 09-02-2008 8:51 AM In reply to
    • kallasr
    • Posts 1,077
    just be sure the panels are attached firmly - as stated above, they tend to get loose over time.
