Latest post 09-10-2008 7:09 AM by Medogsfat. 11 replies.
Page 1 of 1 (12 items)
  • 08-28-2008 4:24 AM
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Beomaster 6500
    Hi all,
              before I start delving too far I was hoping someone may give me a couple of pointers as to the most likely fault with this.
    The problem is that it blows the T4 amp fuse (hidden behind the transformer) as soon as power is swithced on. I haven't done any testing as yet which is pending any help given here.
    Chris.
  • 08-28-2008 11:00 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 6500
    Chris,
    If it blows as soon as the mains plug is inserted into the wall outlet, it could be the mains transformer that has shorted windings.
    If the fuse first blows when taken out of standby it's probably a shorted output stage.
  • 08-28-2008 11:19 AM In reply to
    Re: Beomaster 6500
    I had the same symptom with a BM6500.  Of course, that doesn't mean it was the same problem  .  For me, it was the vertical silver can-type capacitor near the fuse.  (On page 10 of the service manual you'll find this to the right on the rectifier D3).  Page 19, lists it as a 4700uF -10 + 50% 16V Cap.  However, as it's an older receiver and that is a large electrolytic capacitor, you may want to check it first.
     If you have the service manual (available to Gold Members) you should be able to isolate the issue fairly quickly.  Since you know the fuse is blowing instantly, start from there and check every potential path to ground.
     Good Luck!
     -Rob
  • 08-28-2008 11:32 AM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beomaster 6500
    That's great stuff guys,
                                    the mains transformer was one of my suspects (yes Martin it does blow as soon as power is supplied) and the info' on the capacitor to check first is great.Wink
    Chris.
  • 08-28-2008 11:35 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beomaster 6500
    Yes, the large PCB mounted cap ! I also remember replacing one of these. If that is indeed the problem, you should also check (or replace) the associated rectifier.
  • 08-28-2008 11:50 AM In reply to
    Re: Beomaster 6500
    Yep, I replaced the rectifier too - forgot to mention that.
    Thanks Martin!
    -Rob
  • 08-28-2008 2:03 PM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beomaster 6500
    Brilliant!
    I'll keep you postedSmile
    Chris.
  • 08-30-2008 9:13 AM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beomaster 6500
    Right,
             I've checked the power supply/transformer which is fine and removed the board and identified the problem to be the Cap as suggested. Next question is where to get the replacement capacitor & bridge rectifier from.
    Chris.
  • 08-30-2008 9:35 AM In reply to
    Re: Beomaster 6500
    Hello Chris, I'd suggest you get yourself down to Farnells or RS, just the road from you.
    Do you have an account with them, if so you can order and then collect, otherwise you'll have to wait for delivery - in 24 hrs.
  • 08-30-2008 10:11 AM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beomaster 6500
    Thanks Dave,
                         I've found what I need at Farnells but may have a look at RS and see if they have owt.
    Chris.
  • 08-30-2008 11:25 AM In reply to
    Re: Beomaster 6500
    Glad to here that you have found the issue.  Good luck with the repair!
    -Rob
  • 09-10-2008 7:09 AM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beomaster 6500
    Well - here's how it went.
    Been babysitting the grandkids over the past week, but in the meantime I ordered the parts (didn't realise my next door neighbours wife worked for Farnells so they cost me a grand total of £3.00 - happy daysBig Smile).
    Got back home toady at @ 10am and the beomaster was up and running perfectly by 11am, I even replaced the mains lead which had been cut by the previous owner.
    So all in all I reckon you guys have saved me at least an evenings work diagnostics wise so thanks a million you're real starsBig SmileParty!!!
    Chris.
