Latest post 05-13-2007 2:02 PM by brunetto77. 4 replies.
Page 1 of 1 (5 items)
  • 05-12-2007 12:35 PM
    Beocom 5000 battery..still available?
    The battery of my beocom 5000 is at its end now and needs replacement. Do you still find these? On ebay I normally see those for beocom 6000 and beocom 4
    Any help much appreciated
    Bruno
  • 05-12-2007 3:09 PM In reply to
    Re: Beocom 5000 battery..still available?
    I believe this model was based on a Philips or Siemens model so the battery should be a common model. Have you taken it out yet?
  • 05-13-2007 1:50 PM In reply to
    Hi Peter,
    there are three batteries inside that look like 3 AA type. These are linked in pairs. The first to the second and the second to the third. The only name I can see on the small label is UMA Power Ni-Cd 3.6V/800mAh. There is also a number: 1123-39
    Hope this helps
    Bruno
  • 05-13-2007 2:00 PM In reply to
    Bruno,
    The old type batteries in the BeoCom 5000 did not last very long and around 2002 B&O had Sanyo make a new Ni-MH battery for the 5000 which is available from a B&O Dealer. The part number is 8700056
    Keith..
    Regards Keith....
  • 05-13-2007 2:02 PM In reply to
    Thanks Keith!
