Latest post 08-26-2008 1:49 PM by Puncher. 4 replies.
Page 1 of 1 (5 items)
  • 08-26-2008 12:34 PM
    Is there such a thing as an S-video to composite converter?
    Hi:
     This is a little off topic. However, I was wondering if anyone new if there is such a thing as an S-video to composite converter? I am looking to run a single phono cable to the s-video socket on a media server and run the other end to my Beovision 1 and possibly wirelessly to my Avant via a video sender (not the prettiest way of distribution but it should work).
    If not I could just get a videocard with TV out already built in, probably for next to nothing but if I don't have to buy another card then I  would rather not.
     I could just use S video but I never have much luck with those cables and always end up with black and white picture etc which is probably easily remidied yet I now take an instant dislike to S video in general.
    Graham
  • 08-26-2008 1:17 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Is there such a thing as an S-video to composite converter?
    Not sure if this is a "correct" way to do it or a bodge
  • 08-26-2008 1:25 PM In reply to
    You might just try connecting the Y and C signals from the S-video socket together. The composite signal is just a sum of them. This is not the quite correct way to do it, but depending on the equipment, length of cabling, etc, you might get away with it and have a pretty decent picture.
    Many TV out display adapters do just this in their adapters (an S-video plug in the other end and an RCA socket in the other), so you might actually have a ready made solution in a junk box near you.
    -mika
  • 08-26-2008 1:38 PM In reply to
    Hi Puncher:
    The link you provided is broken or moved, could you check it again?
    Graham
  • 08-26-2008 1:49 PM In reply to
    • Puncher
    • Posts 9,588
    Graham1982:
    Hi Puncher:
    Graham
    Quite right - my fault. HERE it is again. (If you get one make sure the S-Video connector has the correct number of pins, they do differ).
