Latest post 05-12-2007 5:51 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 05-12-2007 10:02 AM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    DVD - rw
    I need to buy something to play dvd`s or and blue ray whih fits mx3500 on a stand
    * which hd -rw dvd is best to buy and can be effortless used by link 1000 ( non B&O )
    * which has most striking resemblance  ( slim line ) with a vx5500 ( I like the look of it under the vx3500 )
    * is there already a possibility to send PC tv out wireless to TV with good result ( this for consideration to use pc blue ray ....btw i need as less a sables possible Tongue Tied )
  • 05-12-2007 5:51 PM In reply to
    Re: DVD - rw
    I think the DVD controller will work. Just ask your dealer to check which machines are covered - Panasonic seem to at least partially work.
