Latest post 08-26-2008 4:57 AM by kawo. 5 replies.
Page 1 of 1 (6 items)
  • 08-24-2008 12:36 PM
    • Peroxide
    • Not Ranked
    • Joined on 12-04-2007
    • Gran Canaria-Spain / Sweden
    • Posts 6
    Beolab 4 Ceiling Mount
    Does anyone here know where I can find pictures of Beolab 4 hanging from the ceiling?
    Thinking of doing this myself, but have never actually seen it... would like to know if it looks good or not :)
  • 08-24-2008 12:47 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Beolab 4 Ceiling Mount
    Hi
    There is a photo Here
    Quim
  • 08-24-2008 10:09 PM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-24-2007
    • Atlanta, USA
    • Posts 318
    Don't have a picture but I can confirm that it does look quite nice.  I've got them in the kitchen and a bedroom.  Just be careful if you install them yourself in corners.  Due to the symmetry of the speaker it is crucial to get the mount placement dead accurate to look right.  There is no template and the only way to pre-visualize is to hold the speaker in place while seated in the mount.  The only problem is that once you get the speaker in the place you want it is very tricky to accurately mark the position of the mount as it sandwiched very small between the speaker and the ceiling.  As a result I found it tricky to get the mount placed accurately on the ceiling so that the corners of the speaker would be symmetrically placed in the corner.
    Also, be sure to leave enough room in the corner for the speaker to rotate approx 35 degrees as this is required to attach and detach the speaker from the mount.
    -Michael
  • 08-25-2008 10:30 AM In reply to
    • Peroxide
    • Not Ranked
    • Posts 6
    Thanks guys!
    Indeed it looks nice :)
    Just another question... I saw in a pricelist somewhere that they sell a special version of the front cover for ceiling mounting, part no. 6045...
    What's the difference? Is it just the logo that's upside down or what?
  • 08-26-2008 12:52 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    What I have seen in the pricelist and I think you will need is the part n. 2177. It's a piece to place the BL4 in the ceiling, 25 € each one.
    Cheers
    Quim
  • 08-26-2008 4:57 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    yes, as far as I know the only difference to the standard cover is the direction of the B&O logo.
    I have the Lab4 wall mounted with the ceiling mounting kit. I Don't like the "lamp" style of the wall mount.
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
