Latest post 08-28-2008 10:45 AM by TheTinman. 4 replies.
Page 1 of 1 (5 items)
  • 08-23-2008 4:08 PM
    Techs help, difference between STK amp chips.
    Does anyone know the difference between the STK4151, 4151-II, 4151-V chips?  Looking at the schematics between a beomaster 4500 and beocenter 9500, they seem identical in pinout and parameters.
    I need to replace a MK-V but only have a MK-II.
    Want to make sure before I solder one in.
    Thanks.
  • 08-23-2008 4:50 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Techs help, difference between STK amp chips.
    They are normally backwards compatible in that you will be able to substitute a Mk II with a Mk V. There are probably minor differences, maybe temperature related issues fixed or safety circuits updated as the versions appear. I don't think it will hurt anything to try mouinting a Mk II but the Mk V is fairly inexpensive, so why not get the correct one ?
  • 08-23-2008 8:07 PM In reply to
    Because I have a MK-II in a drawer??
    I checked my beomaster 4500 today while re-gluing the glass.  It is supposed to have the old chip but has a MK-V as well.
    Guess I'll just order one and be done with it then.
    Marc
  • 08-28-2008 6:43 AM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    The MK V has lower distortion than the MK II, they are interchangable otherwise.
  • 08-28-2008 10:45 AM In reply to
    Thanks!  I figured they were, but wanted to be absolutely certain.  In the meantime, I DID locate a MK-V chip and replaced it.
    My 9500 is back to it's former wonderful self.
    My next project is to replace the opamps and caps in the audio path.  ESR on the small caps is getting pretty high.
    Still, for it's age I have no complaints.
