Latest post 08-25-2008 4:33 AM by beoaus. 4 replies.
Page 1 of 1 (5 items)
  • 08-23-2008 12:20 PM
    Beolink active hummmmmsssss...
    Having a tidy up and noticed an annoying hum coming from the black active box? is this normal or is it....
  • 08-24-2008 2:30 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Beolink active hummmmmsssss...
    .......time to be repairedLaughing
    Best regards
    Spiros
  • 08-24-2008 4:26 AM In reply to
    It is not normal in my view.
    How loud is the hum ? or is it more of a buzz ?
    Regards Keith....
  • 08-24-2008 9:51 AM In reply to
    Probably a buzz over a hum... but constant.. and annoying...
  • 08-25-2008 4:33 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    I'd try the obvious first. Flip the power cable, change it, disconnect powerlink, ML....failing those options...
    Dont think they swap the internals out on these anymore, if it's under warranty it would be a replacement or out of warranty a new box..Sad
    Beoaus.
