Latest post 08-22-2008 11:00 AM by Peter. 8 replies.
Page 1 of 1 (9 items)
  • 08-21-2008 11:50 AM
    Beo5 software Download
    Hello Everyone  i bought the Beo5 Remote  and gave it to the dealer to fix the software part etc  , brought it home today to see that Some Of The Channels I told them to put in are missing etc etc.   So Was Wondering If Someone Could Sent me The Beo 5 Programm So i Can Short It Out Myshelf so i dont have to go to the Service Part  Everynow and Then  . I heard that the programm is arround 70 Mb ? So should be possible to sent it to me via email or msn  ...... Contact me Here  :    gobboss@hotmail.com
  • 08-21-2008 12:42 PM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: Beo5 software Download
    Hello,
    It's a real shame, but this software is intended to dealer and only available through B&O's intranet. Furthermore, firmware updates which come with updates are also done through this intranet.
    All you can do is to ask your dealer to "give" you the software, knowing that for each new version, you'll have to take your beo5 to your dealer to have the firmware updated if you wish to take advantage of new features.
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 08-21-2008 1:09 PM In reply to
    Thnx again for ur Reply ,just  found a Version through rapidshare  gonna test if it works ...
  • 08-21-2008 1:45 PM In reply to
    And a Last Question... Is It Possible to Save the Configuration that my Beo 5 Have Already and transfer it to my hard disk so i can work on My Current Setup?  Instead of Making 1 Setup From Scratch ?
  • 08-21-2008 4:31 PM In reply to
    You can store various set ups - however one normally does so using the serial number. Has your Beo5 got the latest firmware - it should be 1.34a.
  • 08-22-2008 7:49 AM In reply to
    Sandrikor:
    Hello Sandrikor,
    for your information: it is not possible to save the current configuration of the Beo5 to harddisk. You have to get your configuration file from your dealer if you don't want to begin from scratch.
    Piet
  • 08-22-2008 8:34 AM In reply to
    Well Went today to the Service Teparment here in Greece to get  the remote shorted out , she refused to give me the file for the beo5 so i wouldnt start from scratch and even refused to accept icons i downloaded myshelf so we could optimise the beo5....what can i say quite dissapointed for the first time,,,,Even told them that i own the programm myshelf but still they their policy are to make the first installation with the stadar icons they have and from that time they have no responsibility what so ever for further programming  ....Well i guess its up to me then to start the installation from scratch etc.....
    Thank you all for the replies
  • 08-22-2008 9:06 AM In reply to
    Your are not the only one with this experience, Sandrikor.
    But you have the software and can do it by yourself. It will take some time the first programming, but after that you have the experience.
    If you have question about the programming, put them on the forum.
    Good luck.
    Piet
  • 08-22-2008 11:00 AM In reply to
    Keith has made a collection of templates for the Beo5. Look at the top of the forum.
