Latest post 08-21-2008 5:32 AM by Weebyx. 3 replies.
Page 1 of 1 (4 items)
  • 08-20-2008 1:42 PM
    Beovision 7 - LED flashing when turned off
    Dear Forum,
     Some 3 weeks ago I got a PS3 which I connected to my Beovision 7, 40" Mark III through the HDMI input.
    Later I have started noticing that a while after having turned off the tele, the red LED starts to flash and keep doing this. I could swear that this didn't happen the first few days that the PS3 was connected to the tele.
    Does anyone have a clue to what this means and how to stop it?
    Cheers,
     Moller
  • 08-20-2008 5:45 PM In reply to
    Re: Beovision 7 - LED flashing when turned off
    We had a similiar problem with our Avant, although without the PS3. Disconnecting the power and then restoring power solved the problem.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 08-21-2008 1:44 AM In reply to
    I have tried your suggestion and for now it seems to work Smile
    Thanks a lot,
    Moller
  • 08-21-2008 5:32 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Moller:
    Dear Forum,
    Cheers,
     Moller
    Yes, i have experinced this also, it seems to be en issue when connecting things to the tv via HDMI/DVI. I had it on my BV7-32 when i connected a PC via DVI, and i have also seen it on my 7-40MKIII when i have been using my PC or PS3 via HDMI. B&O (as usually) has never seen this before, and don't know how to fix it :)
    Disconncting power and reconnecting solves the problem for me.
    /Weebyx
