Latest post 08-19-2008 7:56 AM by alexander_min. 2 replies.
Page 1 of 1 (3 items)
  • 08-19-2008 5:43 AM
    Lintronic + Beo4 + Jung lighting
    Hello there!
    I have a Jung lighting system with RF remote control and I was wondering if I can control it with my Beo4 "LIGHT" Idea button if I install the Lintronic system to convert the Beo4 signal into RF. But I look on the Lintronic site, Jung switches are not on the list of supported lighting system products.
    Any positive (or negative) experiences with the aforementioned setup? Thanks!
    Best regards,
    Alexander
  • 08-19-2008 6:19 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Lintronic + Beo4 + Jung lighting
    I would personally suggest that you should contact Linktronic for this.
    They are very helpful and I'm sure that they could possibly help you on this issue.
    Best regards
    Spiros
  • 08-19-2008 7:56 AM In reply to
    Thanks for the suggestion, they were very helpful and quick-in-reply indeed. They confirmed that my setup is possible indeed.
    Cheers,
    Alexander
